sherman aluminum head question
okbill
02-17-2006 16:27:17
Will a sherman aluminum high compression head fit on a 51n otherwise what is the differance between a early 9n and 8n,i see john smith shows on his page two different heads one for the 9n and one for the 8n,i have been looking for a sherman head for my 51 8n and would like to know if one would fit. thanks bill.
Kelly Jewell (KY)
02-17-2006 18:15:21
 Re: sherman aluminum head question in reply to okbill, 02-17-2006 16:27:17
Bill, they will all bolt up and work 39/52, however the 8N head was changed when the distributor was moved from the front to the side. The new side mount called for threaded holes on the rh front side of the head to mount the new coil. With the side mount dist taking up all the room on the right side, the generator had to be moved to the L.H. side. The oil filter was in the way and had to be relocated slightly to the rear which called for new filter location threaded holes in the head. All new replacement heads have all these threaded holes so will work 39/52....Kelly.
okbill
02-17-2006 18:42:03
 Re: sherman aluminum head question in reply to Kelly Jewell (KY), 02-17-2006 18:15:21
thanks kelly,do you know what years they made the sherman head? bill
Kelly Jewell (KY)
02-17-2006 18:51:56
 Re: sherman aluminum head question in reply to okbill, 02-17-2006 18:42:03
Bill, don't have a clue. I don't think I've ever seen one on a tractor. Had a guy from Indiana tell me he had two. I don't suppose they sold that well or there would be more show up.....Kelly.
Button
02-17-2006 23:22:39
 Re: sherman aluminum head question in reply to Kelly Jewell (KY), 02-17-2006 18:51:56
I just bought one on ebay. I saw one years ago go for $135 and kicked myself for not bidding it higher so when I saw this one I jumped for it. Thought it would look cool all polished up. Now I just found alluminum grills at stiener tractor. Pricey though.
