Order Ford 8N Parts Online
8n pto conversion?
oldcar29
02-17-2006 19:11:49
I have a 8n and would like to convert the 1 1/8 dia pto shaft to the more popular 1 3/8 dia shaft. How is the best way and where can I get the parts? Thanks
Tom - NJ
02-18-2006 15:10:12
 Re: 8n pto conversion? in reply to oldcar29, 02-17-2006 19:11:49
I changed mine in about 15 min, part was about $120, best thing I ever did. With an adapter PTO is too long.The sleeve type is not durable.As they said park tractor on a sharp incline don't need to drain oil out.
K.LaRue-VA
02-18-2006 07:04:48
The down side to changing out that 1-1/8 shaft is that most of the replacement shafts are not as strong. That old 1-1/8 shaft is made out of a lot better metal. I simply bought a 1-1/8 to 1-3/8 adapter sleeve for my PTO pump and a 1-1/8 to 1-3/8 ratchet ORC for my bush hog. Both work just fine.
old
02-17-2006 22:22:11
The cheapest way is to do it with an ORC. Which you need if you want to brush hog with it any how
GAJIM
02-17-2006 20:01:48
I changed mine out last year - bought the complete replacement assembly. Parked the N nose down in a ditch and changed it out in less than 15 minutes - a 4 bolt job. Best thing I ever did was to get rid of the 1 1/14 to 1 3/8 adapter. GA Jim
ericlb
02-17-2006 19:36:32
you can do it by either changing the whole shaft, to the more modern size or, if you do some brushoging, simply order a orc unit that does the conversion for you, i use one on my jubilee and it works great, both are avalible here
OliverDouglas
02-18-2006 04:43:54
 Re: 8n pto conversion? in reply to ericlb, 02-17-2006 19:36:32
where would someone purchase this kit ?
Pooh Bear
02-18-2006 12:26:41
 Re: 8n pto conversion? in reply to OliverDouglas, 02-18-2006 04:43:54
I got mine last fall from this site.
Wasn"t hard to change at all.
Park the nose of the tractor in a deep ditch.
Clean around the PTO shaft real good.
Remove the 4 bolts and pull the shaft out.
Put the new shaft in and tighten the bolts.
Easy Peasy and all that....
Pooh Bear
JohnMD
02-18-2006 05:11:57
Click on parts left side of this page.
oldcar29
02-18-2006 11:54:26
 Re: 8n pto conversion? in reply to JohnMD, 02-18-2006 05:11:57
Thanks for everyones help
