Order Ford 8N Parts Online
cast iron or steel? 8n46533
roy hill
02-18-2006 14:43:15
what is the better of the two cast iron or steel? thanks again!
Jimmyjack
02-18-2006 18:34:23
 Re: cast iron or steel? 8n46533 in reply to roy hill, 02-18-2006 14:43:15
Dawn might not live that long if she doesnt take the time to get Arther lashed up from the top.
Dan
02-18-2006 15:04:00
Stock is steel sleeves for your early 48 8N tractor - but many were bored out for the thicker sleeves early on in their lives. The only way you will know is to pull the head.
Dan
Dan
02-18-2006 15:06:47
 Re: cast iron or steel? 8n46533 in reply to Dan, 02-18-2006 15:04:00
I guess I really didn't answer your question did I... The cast iron is an improvement to the thinner steel sleeves and reduces the "rippling"(sp) effect when put under a heavy load. If it hasn't been done yet, you may consider the upgrade to the thicker cast iron sleeves.
Dan
FarmerDawn
02-18-2006 14:51:47
Do you mean for cylinder sleeves?
roy hill
02-18-2006 14:55:04
 Re: cast iron or steel? 8n46533 in reply to FarmerDawn, 02-18-2006 14:51:47
yes for cyl. sleeves
FarmerDawn
02-18-2006 15:03:38
 Re: cast iron or steel? 8n46533 in reply to roy hill, 02-18-2006 14:55:04
Well...I'm probably way out of my depth here, or else I might not be telling you anything you don't already know. But just in case it's helpful I can say that I know the cast iron sleeves are thicker than the steel ones. If you had steel in your original engine (and your number is low enough that I think you would), you would have to bore out the cylinders to put in cast iron now. I believe you also have to have a lip area reamed into the top of the cylinder because the cast iron ones have a rim or lip that the steel ones don't have. The I&T FO-4 manual has details on exactly how to do this. And you may have already seen that. (In which case, woops.)
If you are asking about the different material properties of cast iron and steel, then, um... Hm. Then you'll have to wait for one of the great old Ford tractor engineer type people to chime in on this thread. (Sorry. I just don't know enough.)
HTH, Dawn
Hobo,NC
02-18-2006 16:59:04
 Re: cast iron or steel? 8n46533 in reply to FarmerDawn, 02-18-2006 15:03:38
Both types have a retain'in lip at the top
FarmerDawn
02-18-2006 17:00:43
 Re: cast iron or steel? 8n46533 in reply to Hobo,NC, 02-18-2006 16:59:04
Woops. Thank you, Hobo. :-)
maplehillfrm,pat
02-18-2006 15:15:37
yea but it sure soundls like you are getting there, in no time at all you will be one of the major N guru's around here, see what happens when you get into a hobby and you start luvin it, pat
FarmerDawn
02-18-2006 15:24:39
 Re: cast iron or steel? 8n46533 in reply to maplehillfrm,pat, 02-18-2006 15:15:37
Well, I sure do love it, I can say that! Now whether or not I can ever be an N guru . . . That remains to be seen! LOL
