Rod pins and Bushings
Nova
04-29-2001 16:03:03
I am rebuilding a 1950 8N, I purchased an overhaul kit that included pistons, rings, Rod bushings, etc. After I installed the new brass bushings in the rods, the piston pins will NOT go through them. I guess they need reamed to size... I have looked in my manual, on the net and no where can I find what size is required. The pins are .750" Do they need sized for the pins? What would be the correct clearance?
Ed Gooding (VA)
04-30-2001 04:21:38
 Re: Rod pins and Bushings in reply to Nova, 04-29-2001 16:03:03
See if this will answer your question:
third party image
Hope this helps..... ..... Ed
'52 8N475798
Nova
04-30-2001 04:34:51
 Re: Re: Rod pins and Bushings in reply to Ed Gooding (VA), 04-30-2001 04:21:38
Thanks Ed and Greg, This is exactly what I was looking for.
Thanks Again!!
Greg
04-29-2001 16:27:05
Hi Nova,
The FO4 manual does not give a specific inside diameter for the bushings. It says clearance is correct when the pin will slide through the bushing slowly just from it's own weight. ( rod horizontal-pin vertical of course ) It doesn't say dry or lubed. I lubed mine and they slid through slowly. Strange but true.
Nova
04-29-2001 17:15:59
 Re: Re: Rod pins and Bushings in reply to Greg, 04-29-2001 16:27:05
Greg,
Thanks for the reply. Did you hand ream the bushings, and if so, to what size?
Greg
04-30-2001 02:23:24
 Re: Re: Re: Rod pins and Bushings in reply to Nova, 04-29-2001 17:15:59
I had a machinist friend of mine take them to .750 then I hit them a little at a time with a small wheel cylinder hone. I would guess them at .7505.
