Sparkplugs
arky
04-29-2001 18:03:17
Hey guys here's a good one.I have a
51 8N engine in my 9N tractor.It runs
real good when i put new plugs in it
for about 10hrs of operation.Then it
starts missing again.I can put new
plugs in it and get about 10 more hrs
of operation.whats my problem here?
the tractor does not smoke or use
oil. thanks arky
bj/8N./mt
04-30-2001 05:03:25
 Re: sparkplugs in reply to arky, 04-29-2001 18:03:17
If you can't remember changing the plug wires or if you have radio wires change them now.
Get the good metal core kind for off road and solder the crimp on ends.
Your mileage may vary
JeffCT
04-29-2001 18:59:58
Arky, Maybe this article could be of some assistance.
Link
peterc
04-29-2001 18:47:01
you may need to run a plug with a different heat range. look in automotive book to see how plugs are fouled and decide if plugs are to hot or to cold.
Snowplow
04-29-2001 18:44:00
You probably have worn rings that are causing fouling. Look at the plugs, are they black? Gooked up? If so that may be from the oil your burning as it slips by the rings. A sure way to tell would be a compression test. If you don't have a gauge you can sometimes rent one from an auto parts store or buy one for about $25. If compression is low, add a couple drops of oil to each cyl. as you recheck. If compression goes up a good bit then rings are worn.
Other things may cause fouled plugs. An over rich fuel mix will muck up plugs especially if you are only using the tractor in short spurts. Close the main adjustment knob then bring it out 2 1/2 turns. Also weak spark. Try a good tune up, it's much cheaper than a rebuild and will need doing anyway!
Good luck!
smokie
04-29-2001 18:10:46
what plugs are you using and gap if all else fales put in some defowlers they worked real good for me until she started smokeing so bad i decided to tare it down work is in progress hope this helps
arky
04-29-2001 18:44:56
 Re: Re: sparkplugs in reply to smokie, 04-29-2001 18:10:46
i am useing autolite #216's what
is he type and # of the defowlers
you are talking about here smokie
Dave Smith
04-30-2001 13:41:32
 Re: Re: Re: sparkplugs in reply to arky, 04-29-2001 18:44:56
Those anti foulers have been around for more than 50 years that I know of. They do work for a while but you are just postponing what you will eventually will have to do.
Dave Smith <*)))><
Danny in CO
04-30-2001 07:38:42
I run Autolite 437s in my 8N. They are a hotter plug than the 216s. The antifoulers are available at NAPA. I think I paid about $1-$2 each for mine.
