Where can I get headlight bulbs
Pooh Bear
02-22-2006 16:36:20
Where can I get headlight bulbs.
I don"t need the whole assembly, just the bulbs.
I can find the assemblies for mucho denairo.
But just the bulbs shouldn"t be that much.
Can I get bulbs from the autoparts store?
early 1949 8N 12volt. 5.75inch bulbs
Thanks.
Pooh Bear
Jim.UT
02-23-2006 11:19:21
 Re: Where can I get headlight bulbs in reply to Pooh Bear, 02-22-2006 16:36:20
SouNguy has given you the correct number for a 12 volt sealed beam lamp for the Tract-O-Lite buckets. The equivalent 6 volt lamp is a 4019. My local farm supply store stocks the 12V but not the 6V. I have to go to NAPA for the 6V. Might be as much as $15, but maybe only $7.
souNdguy
02-22-2006 17:39:30
If you are using the tract-o-lite or similar shells, i use: wagner 4419 or anything that crosses to it. This is the number for the 12v bulb.
Napa, TSC, carquest.. etc.. ( new holland )..
Soundguy
Dave L
02-22-2006 16:59:06
Ya Bear if they are the ones I thinking of(round GE that are held in by rubber or ring clamp) the parts store has them I just bought a pair fer $4.25 a piece.They had two other sizes too just take in your old one to compare.
Dave
Pooh Bear
02-22-2006 20:00:32
 Re: Where can I get headlight bulbs in reply to Dave L, 02-22-2006 16:59:06
Yeah, these are held on by some kind of ring clamp.
Looks like it just takes a screwdriver to remove it.
I"ll try to get a look at it tomorrow and maybe some pictures.
Be great to just take it over to Napa or OReilly"s and match it up.
Thanks.
Pooh Bear
