Order Ford 8N Parts Online
8N Timing
Richard Kelley
02-23-2006 13:56:40
Does anyone have a picture of where the timing mark is ? or where to find it ?
This is a front distributor.
RustyAL
02-24-2006 15:17:40
 Re: 8N Timing in reply to Richard Kelley, 02-23-2006 13:56:40
There is no timming mark on a front mount. There is a way to set the timming before installing the distributor. But it only works when the parts involved are not worn. cam lobes, distributor, distributor drive, lifters etc. I set the timming by ear. Then put the tractor to work under load and readjust.
Tom N MS
02-23-2006 18:20:45
Link
roger '40 9n
02-23-2006 14:54:41
Look in Parts and Pieces for 9N timing.
go here:
tractorshed.com/gallery/pieces/v140.jpg
Roger in Michigan
LeeMo
02-23-2006 14:21:08
Most of the time if you install the points and carefully gap them to .015 you don't need to mess with changing the timing on the front mount tractors. I believe the tune up guide to the left may have the instructions for timing the front mount distributors. If not someone will post a link or something. Good Luck, Lee
