Front engine neoprene seal - Help
Freewheelin'
02-26-2006 14:05:20
I'm told there is a neoprene full circle seal available to replace the original rope seal for the front seal on my 8N. I'd appreciate a source and part number if anyone has it. Any tips on installation? Thanks...
Bob
02-26-2006 18:21:35
 Re: Front engine neoprene seal - Help in reply to Freewheelin', 02-26-2006 14:05:20
I think this one, for the V-8 flatheads, will work, and is one of the better units:
Third Party Image
It is a seal pressed into an aluminum holder, with an "O" ring aound the outside.
Source is : www.parrautomotive.com
It is their part number: HOT9982, @ $35.95 each.
Their phone # is: (405) 942-8677
The alternative is to use a metric seal, 40mm x 62mm x 11mm (NAPA #550199). These will have a neoprene coating around the outside. These should also be available from National or CR. (Some folks swear by 40mm x 62mm x 10mm.) (Size format is seal OD x seal ID x seal width.)
Here's a photo, from the gallery, of some type of full-circle seal installed:
Third Party Image
Tom N MS
02-26-2006 14:14:52
I have a new one you can have for $5 still in the box. You buy it some of these other places they will charge more than that then rip you for $8 shipping..
Freewheelin'
02-26-2006 16:51:59
 Re: Front engine neoprene seal - Help in reply to Tom N MS, 02-26-2006 14:14:52
What brand and how old is it? I don't trust the Chinese junk. :)
Tom N MS
02-26-2006 18:36:26
 Re: Front engine neoprene seal - Help in reply to Freewheelin', 02-26-2006 16:51:59
I don't have it in my hand right now but I'm sure it is NAPA.. I have had it 3-4 months and decided to stay with the rope seal setup..Check with Napa and you might get it direct from them for $5.00. I did not know to check direct with Napa at the time I ordered this one so I paid $6.00 plus an exaggerated shipping cost. Let me know what you find at Napa and if you still need this one I will look it up..
