Order Ford 8N Parts Online
8N PTO
Quinton
02-27-2006 07:43:40
The other day while shredding I got bogged down so I had to take the PTO out of gear and move forward a few feet. When I went to put it back in gear, I physically could not push it in gear. If you let out on the clutch a little you can hear the gears just start to grind, but you cannot push it that extra 1/2" to actually get it to engage. I disconnected the shredder but to no avail. Still wouldn't go in gear. Any ideas, suggestions?
ZANE
02-27-2006 14:20:44
 Re: 8N PTO in reply to Quinton, 02-27-2006 07:43:40
Twisted PTO shaft.
You probably have an aftermarket PTO shaft of the 1-3/8" size and they are all soft as butter compared to the original Ford 1-1/8" PTO shaft which was made from Vanadium Steel. Not recycled Pointaic hub caps.
Zane
Bob Harvey
02-27-2006 18:34:57
 Re: 8N PTO in reply to ZANE, 02-27-2006 14:20:44
P.S. You spelled Pontiac incorrectly---another lawsuit (with two pairs of pants and a vest)is on it's way !!
Bob Harvey
02-27-2006 18:29:16
How dare you impune the "Great Chief" Pontiac !!!!! You will be getting a stiff reprimand from the Bureau of Native Affairs (mind you , they don't ALL have affairs)
Rick H. Ga.
02-27-2006 08:03:27
There is a splined slide connector/coupling that engages the PTO shaft with the lower counter shaft in the transmission when you move the PTO lever rearward. There is a possibility that it will not engage due to stress or ware; or (worse case scenario) your PTO shaft is warped/twisted. It is also a possibility your rear PTO bearing is wore badly causing your problem (this usually results in the PTO slipping out of gear when engaged).
If it were me, I"d remove the inspection plate on the left side (PTO lever) and see if I could get it to engage manually (with tractor not running, of course). There is a detent ball and spring in there to help keep it engaged.
It seems like I read the other day that someone on the N board serviced their PTO gear box without splitting the tractor.
HTH. Rick
