Order Ford 9N Parts Online
9n engine oil pump front main assembly
Romulo Gonzalez
02-27-2006 17:30:57
I am looking for the front main w/oil pump assembly for a 9n tractor. bought tractor disassembled, but it was missing this assembly. Could you help me find one new or used cheap!
Kelly Jewell (KY)
02-27-2006 18:34:00
 Re: 9n engine oil pump front main assembly in reply to Romulo Gonzalez, 02-27-2006 17:30:57
Romulo, Dell is correct on the used oil pump assy about align boring. However, the new replacements that I have seen and sold are designed to self center with the upper half of the main bearing cap and seem to work quite well.....Kelly.
Dell (WA)
02-27-2006 17:49:51
Rommie..... ....don't mucka'round; byte the bullet. New OILPUMP is about $100 (not cheap) but you can't buy a good used oilpump. Besides, new or used, you will haffta gittchur oilpump line-bored to match your crankshaft front bearing. (automotive machineshops do this all the time) Why do you haffta line-bore your oilpump? because it is also the front bearing cap. Do it right, the first time..... ...respectfully, Dell
TheOldHokie
02-28-2006 07:33:59
 Re: 9n engine oil pump front main assembly in reply to Dell (WA), 02-27-2006 17:49:51
I've heard this discussion of line boring before and I'm a bit confused. I've had camways line bored to install new bearings where there were none originally or repair blocks with spun bearings. No bearing caps in those cases and oversize (OD) bearings are installed on all journals. Is that the process used on the N cranks?
WRT the idea of a "self-centering" pump housing/bearing cap I'm even more confused. ISTR there's quite a bit of side clearance in the mounting stud holes in an N engine and there's no locating boss for the caps so lateral alignment is no biggy new or used. But if the original or replacement bore is a little low or high (wrt crankshaft centerline) that's not going to self-correct. The two halves are not perfect semi-circles.
I have no idea what the original manufacturing tolerances were on that operation but even a couple thou out's going to be unacceptable. OTOH if the original bore centerlines were held to less than .001 vertically any pump housing or cap would self-center.
TOH
Bob
02-28-2006 08:48:59
 Re: 9n engine oil pump front main assembly in reply to TheOldHokie, 02-28-2006 07:33:59
Let's face it, with their low HP, low compression, and relatively low speed you can "get by" with a lot of things on one of these engines that would not past muster with a precision engine builder.
I have rebuilt more of these engines, as well as flathead V-8's, small block Chevies, and other engines than I care to think about, yet, seldom, if ever, have I had an oil pressure "issue" with and engine I've rebuilt.
Yet, there are posts on here all the time about low oil pressure in a "rebuilt" engine.
A little attention to detail, and not "cutting corners" to save a few bucks on a already costly rebuild will save being disappointed with the results of the OH, having to to it over again, or even losing the engine to a "thrown rod" or a spun bearing.
What you can usually "get by with" if you are OH'ing the engine yourself, and are willing to live with the results is not the same as doing it correctly, or especially, doing a professional job for someone else!
TheOldHokie
02-28-2006 11:22:36
 Re: 9n engine oil pump front main assembly in reply to Bob, 02-28-2006 08:48:59
Bob,
I'm in total agreement with all you said and heartily endorse your suggestion to do it right the first time. But I fail to see how that relates to my original post.
Even in a low performance engine the bore in the bearing caps HAS to be concentric with the other half of the bore in the block. That's usually accomplished by bolting the caps to the web and line boring the assembly. Now you have non-interchangeable matched sets because the boring operation is usually off center (up/down/right/left) slightly. Reverse or replace a cap and you're going to bind the crank journal when you tighten the cap down - the resulting holes won't be round when the mismatched halfs are joined. Since bearing clearances are roughly .002 there's little room for error.
In an N engine were the caps "float" around the main bearing studs/bolts there's probably enough lateral clearance to adjust for centerline error side-to side. But that cannot adjust for vertical error in boring. So how can you make a self-aligning pump body (AKA cap)?
TOH
Bill (BC)
02-27-2006 20:58:53
 Welcome Home Dell in reply to Dell (WA), 02-27-2006 17:49:51
Good to have you back.
Had a suspicion you may have run off with a Deere ??
ZANE
02-27-2006 18:33:23
Welcome back!
Where in the HEdouble hockey sticks have you been!
Zane
