COOLENT
RAVI
02-28-2006 13:52:32
ANYONE USING THE NEW LONG LIFE COOLENT IN THERE 8N ? ANY OPINIONS ON COULD IT BE USED ?
gahorN
02-28-2006 19:02:12
 Re: COOLENT in reply to RAVI, 02-28-2006 13:52:32
Yes. It'll do just as well as the old Prestone antifreeze will. It supposedly lasts longer than the 3 years of the original stuff. It supposedly lasts 5 years. I never had any problem with the 3-year stuff lasting 5-years, tho'. (They just didn't charge so much for it.)
K.LaRue-VA
02-28-2006 19:34:12
 Re: COOLENT in reply to gahorN, 02-28-2006 19:02:12
The only reason regular coolint won't last 10 years is the lube and antirust portion only lasts about 12 months. The extended service coolont has better lubricants and rust proofing stuff in it so they say it can go 5 years. But this is in a modern closed-loop system, with a coolent recovery tank, and little or no air in the system. In your tractor, you are probably adding enough new coolunt just topping-off occasionally that whatever you use in there will last darn near forever. But your tractor is not a closed system, so every time it cools down dirt and air get sucked back in. After a few months of that, you should drain and flush anyway, so Id just run the regular stuff.
dan hill
03-01-2006 01:11:26
 Re: COOLENT in reply to K.LaRue-VA, 02-28-2006 19:34:12
My old JD has had the same perm antifreeze in it for many years.I test it in the fall,add antifreeze if needed.If top off is needed add 50/50 mix.Since perm antifreeze is a deadly poison you dont want to be draining it out often.It has a sweet taste and destroys the kidneys of dogs, cats ,live stock and children that get into it.You can buy additives if it makes you feel better.
souNdguy
03-01-2006 11:46:43
 Re: COOLENT in reply to dan hill, 03-01-2006 01:11:26
You running that 50/50 in a thermosyphon unit?
Soundguy
Dan hill
03-01-2006 14:58:48
 Re: COOLENT in reply to souNdguy, 03-01-2006 11:46:43
No water pump on JD model H.
souNdguy
03-01-2006 15:04:32
 Re: COOLENT in reply to Dan hill, 03-01-2006 14:58:48
That's what I was asking.. down here in florida I havn't had good luck with 50/50 mix in thermosyphon units like my JD-B and yanmar 1700.. have to run more like 70/30 weaker mix..
Soundguy
