OT: old welder
Rip VanWinkle
03-01-2006 04:20:15
I have an old allmand bros welder. The cover has been repainted. I cant tell if it is an ac-dc machine. It has the slip on leads with four post on the front. Any one have experience with these?
Strick
03-08-2006 12:04:20
 Re: OT: old welder in reply to Rip VanWinkle, 03-01-2006 04:20:15
Without being able to see the machine it's hard to tell weather it's AC or DC or AC/DC. What you can do is take a 7018 3/32" electrode "welding rod" run a flat weld between a seting of 80-90; using a negative ground and a positive lead. If the weld after the slag is cleaned off is smooth with out a lot of weld splatter the machine is probaly DC. If there is a lot of weld splatter the machine is probaly AC. Check the back panel and see if there is a label plate that shows what the amps, volts and electrical is for this machine. It should tell you your duty cycles "AC/DC".
Rip VanWinkle
03-01-2006 17:36:03
I'll try to post a picture tommorow.
souNdguy
03-01-2006 11:19:51
Got a VOM?
Soundguy
old
03-01-2006 07:01:46
Most old wleders are AC only but there where/are a few that are both. A lot of them if AC/DC have more the one switch for switching from AC to DC. Post a picture of it and some one might be able to help you more with it
Ken Crisman
03-01-2006 05:20:52
I believe Kim put this in the wrong section . This is for the Ns questions . Sorry I can't help with that . But there ia an old welder around here once in awhile . Good luck . Ken
maplehillfrm,pat
03-01-2006 05:36:47
 Re: OT: old welder in reply to Ken Crisman, 03-01-2006 05:20:52
Its probably in the right section, thats why he put "OT" off topic,, there are a lot of questions asked here that are not directly related to tractors, because there is alot of people here that know more than just N series tractors, pat
