Head bolt lenght?
8n/3130
03-01-2006 09:03:26
My 8n needs another head, old one was cracked. Got the new head and gasket. From posts on this site and others, I see reference to differ lenght bolts. Mine are all the same. Except the the two studs where the wiring tube attachs. What is the story on the Bolts. My manual don't say anything about it. If there is a difference, where do they go?
8n/3130
03-01-2006 18:41:35
 Re: Head bolt lenght? in reply to 8n/3130, 03-01-2006 09:03:26
Thanks Dell!
I knew about the one thread thing for the studs. But I wasn't sure about the bolts. Mine has two studs for the wiring tube, rest are bolts. What is this sealer you speak of for the bolts. I have the copper coat for the gasket. Would NAPA have it.
BTW: Do you torque with the tube and Alt bracket in place or complete everything then come back.
Can't see as it would matter but I'm not sure.
Dell (WA)
03-01-2006 11:49:58
I'm certain you understand the difference between headstuds and headbolts, don't you?
Sometime in 1950 Ford changed from the dual-thread headstud to the coarse-thread headbolt. p/n 8N-6065, 7/16-14 x 2-3/8". Retrofittable to ALL N-Engines. Infact, the N-Ford MPC doesn't even list headstuds anymore. (yet their picture breakouts show studs and nuts)
Yes, the headstuds are different lengths, to accommodate both the sparkie tube legs, and the r/h genny bracket tensioning bracket. The castiron coarse-thread length stays the same, and the Harry Ferguson demanded fine-thread length varies to meet the 1-thread showing beyound the studnut requirement.
The p/n for the head-studs are: 40-6066 (3" dual-thread stud) and 18-6066 (2-3/4" dual-thread stud). p/n 351025 for 7/16-20 stud-nut.
I'm certain that I don't haffta remind you to clean-thread all yer block holes (7/16-14) and make certain your blind corner holes are clear and DRY. (use Q-tips) Why? because you can actually hydraulic crack the corner off when you install. Many use sealing puckey on the wet holes. Remember, torque stud-nuts to 55ft/lbs and headbolts to 70ft/lbs. Retorque after start-up while still warm..... ..Dell
