Single Wire Generator
41Texas2N
04-30-2001 09:02:35
Until recently my old single wire Generator has been charging my battery. I now see no indications of it charging and it drains the battery. This is a 12V system. I have seen references on the board that this old Generator is sometimes more trouble than it is worth. Do you have any suggestions on what I need to do to replace it, and with what if it needs it. Or is there maybe another problem that I am missing.
Thank You,
Chuck
TimK
04-30-2001 10:00:33
 Re: Single Wire Generator in reply to 41Texas2N, 04-30-2001 09:02:35
The first thing that hits me as wrong is a 6v generator won't charge a 12v battery. So, I don't know if in fact you have a ground somewhere draining the batterey, or just the wrong charging system. OR..... ....you are using the wrong nomenclature, and you really have an alternator. Which is it ?
41Texas2N
05-01-2001 04:42:06
 Re: Re: Single Wire Generator in reply to TimK, 04-30-2001 10:00:33
Good question. I'm pretty sure that it is a single wire generator. It was this way when I got it. What I'm calling a generator is a unit about 9 inches long with a single wire. I loaned out my parts book, so I don't know for sure.
Jim WI
05-01-2001 10:51:17
 Re: Re: Re: Single Wire Generator in reply to 41Texas2N, 05-01-2001 04:42:06
Sure sounds like an OEM 6v generator...
I hear it's possible to get that generator to charge a 12v battery. It's not designed for it though and maybe the stress killed it?
'Course, it's likely to be pretty old anyway and maybe it was just its time.
