maplehillfrm,pat
03-03-2006 13:54:17
Re: Ford won't fire in reply to RDP1957, 03-03-2006 11:57:43
As of yet I dont believe there is a real way to check the coil, it is sorta it works or it dont,as this is 12 volt is it a 12 volt coil in there , I think it may need some kind of reducing resistor in there as well ??? they always talk about 12 volt conversions, but I never pay too much mind to it as all mine are 6 volt ,,,,,as far as checking the points and setting them you know the easiest way is to take the front mount dist right off the tractor with 2 bolts right, there is only 1 way to put it back in,,,I would pick a new coil,,after you pull the pigtail down,,,, if it still dont start,look at the way the points were put back in, sometimes the wire grounds by the cond,, have a good day pat the front mount distributors arent very robust on these tractors anyway, so you should keep a spare around, they capture a lot of heat from the radiator.
