OT: Chainsaw repair
Paul Schultz
03-03-2006 19:35:45
Once again, I return with an OT message regarding my chainsaw....
I'm replacing the drive sprocket and clutch assembly on a Craftsman 18" chainsaw. The parts arrived today. I'm having trouble unscrewing the old clutch assembly from the drive shaft.
I am aware that it is reverse threaded (the clutch actually has "Off -->" embossed on the surface to show the direction to loosen). Every time I try to loosen it the drive shaft rotates. I've used a wrench on the opposite end of the drive shaft (it has a nut on it) to hold things in place. I just don't have the proper tool to grip the clutch assembly so I can unscrew it. I even tried to use a well placed large screw driver as a punch and hit it with a hammer to loosed the clutch.....no luck.
Does anyone have any pearls of wisdom on how to get this thing off? I want to use it this weekend and need to replace the worn drive sprocket.
TIA,
Paul.
guest
03-04-2006 04:29:50
 Re: OT: Chainsaw repair in reply to Paul Schultz, 03-03-2006 19:35:45
third party image
If you have an aircompressor or a
buddy has one. Just get an inexpensive
1/2 in drive impact wrench. It will spin off with almost no pressure on the clutch.
George
Paul Schultz
03-04-2006 10:46:57
 Re: OT: Chainsaw repair in reply to guest, 03-04-2006 04:29:50
Thanks for the idea. I do have an air compressor and impact wrench. Unfortunately, the clutch screws on directly and an impact socket would not fit.
The good news is that I got the clutch off. I used an offset wrench to hold the opposite end of the drive shaft stationary. I then used a large flat head screw driver as a punch and a few blows with the hammer loosened the clutch mechanism.
I've already used the chainsaw with the new clutch, chain bar, chain. It is like having a new chainsaw!
Thanks to all for your suggestions.
Paul.
Tom N MS
03-03-2006 20:22:57
Remove the spark plug and stuff several feet of 1/8" rope/cord into the sparkplug hole. Keep the loose end hanging out so you can pull the cord out once the trick is done...Rope stuffed in the hole on top of the p[iston will keep the crank from turning and you should win the battle..
Dan Hill
03-04-2006 12:24:13
 Re: OT: Chainsaw repair in reply to Tom N MS, 03-03-2006 20:22:57
There is a plastic plug that screws in to the spark plug hole.This keeps the crank from turning.
Tom N MS
03-04-2006 14:52:21
 Re: OT: Chainsaw repair in reply to Dan Hill, 03-04-2006 12:24:13
Thanks, I have never seen one. Gotta be a better and faster way than the rope but in a situation where nothing else is available it will work.
