maplehillfrm,pat
03-04-2006 16:05:25
Re: log splitters for a 8 n ford tractor in reply to STIX DOUGLAS, 03-04-2006 09:43:57
well I used to use the neighbors splitter for years,, he had it for years prior to that, was a homemade trailer mounted splitter, was pulled behind the tractor , when you get to the pile hook up your pto shaft to a hydraulic pump he got off of an old loader that the county was done with, plumbedit in with 1/2" hydro line and a reservoir,,hooked to a hydro lever .. and a way we went, the cylinder was a purchase from farm store ,, and the wedge was the formed from a piece of fat steel,maybe 1",, but I think they sell wedges,, and the whole thing was mounted on an I beam, these are easily obtained at auctions fairly cheap, axles were just attached to that and away you go,worked off of any tractor with a pto,, which was good until everyone started borrowing it, and you had to make an appointgment to use it.. I can probably get a picture if you want to see waht it looks like, I ended up getting a vertical splitter , converted it to a horizonal with the help of an old sprayer frame , but I have a TN55, that has way enuff hydro pump power to run with lines hooked directly to it, no one can borrow mine though because the tractor has to go with it, and very few people will borrow the tractor and all, just a thought,pat
