Won't lift the load !
Ron861
03-05-2006 09:19:43
Yesterday I decided to tackle the hyd.problem on my 51 8n. I just bought the tractor a couple months ago,the 3 point went up and down just fine but when I put load on it,300 or 400 lb.no lift. At first I found no obvious problem, other than there was not a gasket on the top cover , just RTV, not a good idea! But on closer inspection of the pump I found a crack in the alu. housing of the pump just above the relief valve can this be welded or replaced. Thanks
DickTN
03-05-2006 09:43:34
 Re: Won't lift the load ! in reply to Ron861, 03-05-2006 09:19:43
Don't know, but welding aluminum is tricky. There's a pump on E-Bay, item #5671356372 at the moment. Might want to take a look. It's not mine, just happened to see it.
