Order Ford 9N Parts Online
40' 9N Generator Problem
AlwaysA?
03-05-2006 14:14:30
The 1-wire generator for my 1940 9N won't charge the battery. The Generator Shop says the generator is putting out just fine. When I got it back from the generator shop it would charge a little bit if I reved up the engine but now it isn't charging at all. Any ideas as to the problem?
maplehillfrm,pat
03-05-2006 17:21:47
 Re: 40' 9N Generator Problem in reply to AlwaysA?, 03-05-2006 14:14:30
if your wiring is ok and your gen is ok and you polorized it , you may need a new cutout relay can
Joe (IN)
03-05-2006 15:26:26
Did you polarize it when you reinstalled it? If not, take a short piece of wire and short between the two terminals on the cutout relay with the engine off for about 5 seconds. Fire it up and see what you get.
Bob
03-05-2006 14:37:45
To rule out wiring problems, check the voltage at the generator, and at both sides of the cutout.
Use an analog meter, or a quality digital meter, as "cheapy" digital meters can be confused by the electrical noise from the igntion and charging systems on these old beasts, and give really goofy readings.
A 6-Volt system will charge at close to 7.4 Volts.
