Front loader won't Fit
Ralph Fulton (S
03-08-2006 08:10:28
I bought an old FORD front loader. For my '50 8N dimensionally all seems to be right, except the front plate. It has two horizontal rows of four holes on the FL. And the tractor has, as far as I can see, one row of three holes. Also I don't have a shaft for the front of the engine, nor do I know what size.
Can anyone make heads or tails out of my description? Please help if you can.
Hobo,NC
03-08-2006 10:22:20
 Re: Front loader won't Fit in reply to Ralph Fulton (Steamboat), 03-08-2006 08:10:28
hobo1301@alltel.net
Ralph Fulton
03-08-2006 09:59:26
I dodn't know how to send pictures to you. If I had your e-mail address I could with no problem.
I just went out and took pictures to send. And I have to de-paint the ID tag before I can give you a model number of the loader.
Ralph Fulton
03-08-2006 10:12:43
 Re: Front loader won't Fit in reply to Ralph Fulton, 03-08-2006 09:59:26
Most of the Info. on the ID tag on the loader has been wiped out, but across the bottom edge was as follows:D110 FO 593 there is no way for me to know what these stampigs refered to.
lonestarjeff
03-08-2006 08:44:12
What's the model # of your loader? There should be a mounting plate or assembly separate from the loader that mounts to the tractor's front pivot housing. Sound like what you have?
The pump drive requires a special crank pulley be installed. The pulley recieves a bolted or pinned hub which is center-drilled for the shaft.
Do you have the original pulley on the front of your crank?
Jeff
Hobo,NC
03-08-2006 08:35:23
The pump drive shaft parts are no problem i have'em in stock. A pix of the loader and front mount would help
