Positive Ground
R.M. In AL
03-10-2006 19:02:39
I have a 12 Volt positive ground 8n and I am thinking of installing a winch on it.If I bolt it down how will I hook it to the battery Pos to Pos and Gr to Gr. or will that blow a hole in the universe...R.M. In AL.
guest
03-11-2006 04:10:35
 Re: Positive Ground in reply to R.M. In AL, 03-10-2006 19:02:39
I thought that a 12 volt conversion
is always Negative Ground. I would check
into that first.
R.M. In AL
03-11-2006 13:31:32
 Re: Positive Ground in reply to guest, 03-11-2006 04:10:35
Not always Guest.This one is Pos.Ground.That means the + on the battery is grounded to the tractor body. Been that way ever since I had it 17 years. Works excellent..Hope this helps you...R.M. In AL.
Mike S
03-11-2006 18:07:04
 Re: Positive Ground in reply to R.M. In AL, 03-11-2006 13:31:32
Are you using an alternator or a generator for your 12 volts production?
R.M. In AL.
03-11-2006 18:22:37
 Re: Positive Ground in reply to Mike S, 03-11-2006 18:07:04
Generator.Its been there since I purchased the tractor no rebuild or anything.Lucky I guess..... R.M. In AL.
Bob
03-10-2006 19:06:05
A LOT of variables there, depending upon how the winch is set up.
Does it have a permanent magnet motor?
Is any part of the motor or reversing switch system grounded to the frame of the winch, or are there 2 discreet (red and black) cables coming out of the winch that have no connection to the winch's metal framework?
R.M. In AL
03-11-2006 13:41:35
 Re: Positive Ground in reply to Bob, 03-10-2006 19:06:05
Bob I'm thinking it would be just like the lights or horn.If I bolt it down it will be positive already and all I will need is a wire going back to the negative side of the batt. to make it run..What do you think.. and yes it does have a magnetic motor would that change things? Thanks R.M. In AL.
Bob
03-11-2006 18:59:46
 Re: Positive Ground in reply to R.M. In AL, 03-11-2006 13:41:35
A permanent magnet field DC motor will reverse with a swap of the power supply polarity, so, if the switch is marked "fwd" and "rev", it may do the opposite of what is indicated.
