sticking clutch
357 tex
03-13-2006 18:29:11
I just bought a 1950 8n.It runs great pulls good,but the clutch sticks almost ever time.I have tried bloking it down,dropping the plows down and slipping the clucth in 4 gear.It still sticks.On the bottom the cotter key is oily,it is seeping oil of some kind seems thin.I am going to chang out the gear oil to 90 wt.What else can I try with out putting a new clutch in?
357tex
03-16-2006 13:38:55
 Re: sticking clutch in reply to 357 tex, 03-13-2006 18:29:11
thanks guys I sprayed 2 cans of brake cleaner in the inspction hole then plowed 2 acres.the clutch now works free and clean.I have been blocking the petal down .
dave8n
03-13-2006 19:09:19
Found this in the archives!!!!
357tex
03-13-2006 20:16:25
 Re: sticking clutch in reply to dave8n, 03-13-2006 19:09:19
Thank you dave8n
I had thought about spraying brake cleaner in the hole in the side where you look at timing marks.But was not sure if it would hurt any thing.I will try it .
souNdguy
03-14-2006 04:35:37
 Re: sticking clutch in reply to 357tex, 03-13-2006 20:16:25
Brake / Carb cleaner won't hurt much down there.. and Do go to the heavier oil.. and don't overfill.. Just fill till it dribbles from the lower bolt hole in the round dipstick cover.. that way oil won't be pooled around the tranny input shaft seal or the axle seals.. And keep the clutch blocked when not in use..
Soundguy
