In lieu of wisdom, good suggestions will be appreciated...I have the left rear side of a 47 2N pulled apart to replace the brake shoes (will do the right side next). The 2N requires you pull the axel as well as the bearing and hub as an assembly in order to get to the breaks. The FO 4 manual says to get to the wheel bearings you should drill a 1/4 inch hole in the seal retainer (as best as I can see) and then split it with a chisel to get the part out. Reassembly requires replacing the bearing, seal, and any other parts destroyed by the process. Two Questions: 1. Are the wheel bearings only lubed by packing them on re-assembly? Seems I read somewhere that they get lubed by tranny/hydraulic fluid down the axle trumpets from the differential. The way the seal is installed, I don't see that happening any time soon... Might be true for the 8Ns... 2. Is there some way you can get to the bearings and re-pack them without destroying the existing parts? Seal is nice and pliable and doesn't appear to need replacement at this time. Seems you should be able to pop the seal somehow with minimal damage and then clean and re-pack the bearings without destroying/replacing lots of parts. Any help or suggestions from the extensive site knowledge base will be appreciated. v/r Richard
