Brake Pedal Adjustments
8N'r
03-15-2006 16:15:40
The brakes on my 8N seem to work fine. However, the brake pedals need to be equalized(leveled). I understand this is done by adjusting the left brake rod clevis and will make it easier to apply both brakes at once. If I make this adjustment, will the actual brakes then need to be re-adjusted as well? There is almost a 3" height differnce in the pedals, left brake being lower. Thanks--Tim
souNdguy
03-15-2006 17:19:43
 Re: Brake Pedal Adjustments in reply to 8N'r, 03-15-2006 16:15:40
The clevis will effect pedal height.
Good luck on adjusting it. When i adjusted my 660.. the threads were so rusty that it broke, and i had to buy a rod and weld new clevis ends on it, along with adding a threaded section as an adjuster.. So.. I reccomend you hit it with a wire brush to clean paint and debri from the threads.. then soak it with penetrating oil.. and if it is stuck.. a little heat.. and more oil..
No.. won't have to readjust brakes..
Soundguy
Ozlander
03-15-2006 17:28:51
 Re: Brake Pedal Adjustments in reply to souNdguy, 03-15-2006 17:19:43
I just did mine. I just fiddled around with the brake adjustment until the pedals were the same. Not real critical on a tractor.
