no spark
paul in maine
03-16-2006 08:39:36
ok kinda new here but have an off board question for all here ... have a harley davidson golf cart everything seems ok on it cranks fine , get spark to points but for the life of me cant figure why no spark to plug . guess im gettin old an my mechanic skills are shot lol , might need to put me out to pasture along with the carts an the 8n thanks for any replies ,, paul
ezyed
03-16-2006 17:21:34
 Re: no spark in reply to paul in maine, 03-16-2006 08:39:36
change your spark plug wire to solid copper,that should do the trick.Graphite wires goo bad for many reasons. An old golf car mechanic
Dave L
03-16-2006 16:47:00
I had pretty much the same problem with my 3 wheel harley cart also,if the advice you got already doesn't fix the problem check that the points plate is making a good ground,that ended up being my problem.Sinple fix but I was pulling out my hair til I fount it.Just my $.02
Dave
souNdguy
03-16-2006 10:23:29
Define 'spark to the points'.
Are you getting a voltage reading at the wire going to the points.. or do you see an excessive spark across the points when they open ( if you do.. your condensor is bad.. ).
If you have power to the points, ensure that they are closing.. check voltage reading... if they are closing and opening.. then check ignition coil. secondary.
Also, ensure that yuo are getting correct voltage at coil primary..
Soundguy
paul in maine
03-16-2006 11:02:26
 Re: no spark in reply to souNdguy, 03-16-2006 10:23:29
hi see nice blue white spark at points when open an close , and i know this may be stupid ha ha ha but when holdin the plug get weak shock so gettin a lil spark to it but not nice hot spark
R.D.F.
03-16-2006 11:23:06
 Re: no spark in reply to paul in maine, 03-16-2006 11:02:26
Here"s a new one for you guys. We work on lots of these tractors, have for over 40 years, just received a stock of new caps and rotors for the front distributors(same supplier for years), couldn"t make a customer tractor run worth a hoot. Started checking parts, 1 out of every 4 new caps were made right, rotors, 4 out of 10 rotors were right. Bottom line, check the new parts very closely, can cause real grief. Dale
souNdguy
03-16-2006 11:16:58
I'd replace the condensor first.. then i'd repalce the spark plug wire.. see where that gets you..
Soundguy
paul in maine
03-16-2006 11:52:27
 Re: no spark in reply to souNdguy, 03-16-2006 11:16:58
ok sounds like a plan to me thanks souNdguy will keep you updated paul
