The "heat range" of a spark plug is not about a "HOT" spark. Heat range refers to how well the heat from the insulated electrode is carried away to the metal housing of the spark plug, and from there to the cylinder head. In a given engine, a spark plug that is too "COOL", heat range wise, will not get hot enough to burn fouling deposits off, and will foul. A spark plug that is too "HOT" will get incandescent at the tip, and cause pre-ignition of the fuel charge, before spark occurs, which will cause knock and piston damage. For a given engine, and also the way you are using the engine, the correct spark plug will be between those extremes. Typically, a lot of these tractors spend a lot of time putzing around the yard, or whatever, and often are not worked hard for a 12 hour day, as they were when they were someone's main farm tractor. Therefore, a "hotter" plug works better, because it will heat up enough at the lighter engine loads to burn the tip clean, that's where the "437's" come in.
