12V wiring and starting issues
SM Jeffries
03-24-2006 05:38:31
Hello Ladies and Gents:
New to board. Appreciate your combined knowledge.
Front mount 8n. New parts and wires. 12v conversion. followed wiring diagrams (myoldfords) exactly.
Problem: Hooking up battery-engine will turn over without key or starter button activation. New solenoid will click when starter button pushed.
What am I missing? thanks in advance
DaveTx
03-24-2006 08:12:29
 Re: 12V wiring and starting issues in reply to SM Jeffries, 03-24-2006 05:38:31
Had a similar problem when I rewired my 6 volt 8N. After starting my tractor would not turn off with key. I had a wire going to the wrong side of the terminal block. Chanches are you do not have it wired correctly. I would check other diagrams to see how they compare. Here is a link to a pretty good one. Link
SM Jeffries
04-20-2006 09:50:42
 Re: 12V wiring and starting issues in reply to DaveTx, 03-24-2006 08:12:29
Thanks fellows. The link provided the correct info. Cranked up as I hoped.
thanks again
old
03-24-2006 08:08:54
Did you replace the soliniod?? If so you probably have the wrong type. Also just to let you know, the ignition switch can be on or off and the starter on these Ns will turn the engine over when you hit the button.
