Order Ford 9N Parts Online
ford 9n electrical
peteny
03-25-2006 10:28:08
rebuilt 9n engine, the 12 volt conversion kit added, front mount distributor, 12 volt coil. When the engine warms up it starts skipping, not sure if it is electrical or fuel related. Anyone have this problem, it also has a new carbuerator. Thanks.
Dell (WA)
03-25-2006 12:54:43
 Re: ford 9n electrical in reply to peteny, 03-25-2006 10:28:08
Pete..... .....there are 4-common runtime issues with the frontmount 9N-engine.
1) runs for about 1-min before it starts missing from weak sparkies; bad condenser
could be yer problem, but you wern't explanitory enuff
2) runs for about 5-mins before it starts missin' from weak mixture; clogged fuel filters could be yer problem, but you wern't explanitory enuff
3) runs for about 15-mins before it starts missing from weak sparkies; gunked ignition switch
most likely yer problem, but you wern't explanitory enuff for certainity
4) runs for about 1-hr before it starts missing from weak sparkies; bad ignition coil
NOT yer stated problem
HTH..... ....Dell
old
03-25-2006 12:08:42
As bob says and or maybe a bad ignition switch.
Bob
03-25-2006 12:35:38
 Re: ford 9n electrical in reply to old, 03-25-2006 12:08:42
Geez, old, I checked out your 'site. You're even more of a wooly booger than me!
Third Party Image
{That unflattering photo was snapped by my 6-y.o.!)
old
03-25-2006 13:42:53
 Re: ford 9n electrical in reply to Bob, 03-25-2006 12:35:38
Thats just my winter look, I use it to hide in the woods from the deer etc, and also to keep the face warm. I'n the summer its trimmed and or off. Only shave every other year or so and then it doesn't seen to stay off long. Guess I'm to lazy the shave much or to cheap to buy razors LOL
Bob
03-25-2006 10:54:58
It could be the coil or the condensor.
Do you have a 1/2 Ohm "current limiting resistor" ahead of your "12-Volt" coil?
Does adjusting the mixture screw have any effect on how it runs when it's missing?
