Order Ford 8N Parts Online
Fixed the 8N charging problem
Alex Dula
03-25-2006 17:50:35
Well it good to have the 8N charging again. I wrote a couple of weeks ago that it quit charging and there was a squeel from the alternator.
Well the alternator was good and so was everthing else except the belt. I had uses a 1/2 inch belt for 10 years or so but it finnally would not tighten up anymore.
So I put a 5/8 to 3/4 inch pulley on the Delco 10SI and a new 11/16 belt. It charged fine and is back to running good. There is much to be said for the wider belt and pulley.
Thanks for all your help.
P.S.
I see another thread on 3 verses 4 ring pistons. When I rebuilt the engine I put 4 ring pistons and rings in. They are working OK but they may wear quicker that the 3 ring. Only time will tell.
Alex
