James, don't think you are alone when it comes to reading schematics. To most people, they a conglomerated mess of wires, resisters, coils, capacitors, and switches. But if you will separate the schematics into the (4) circuits that are present in a 9n tractor, it becomes quite simple. To really make it simple, print out the schematics and using 4 different colors of "high-lighters", highlight each circuit. 1. Charging circuit: Its just a wire running from the large post on back of the alternator to the "common connection" point on the terminal board. From that point, run another wire to one side of the ampmeter and from the other side of the ampmeter, run a wire to the battery side of the starter switch. The large battery cable takes this charge up to the battery. (one color) 2. Starter circuit: This is the large wire that runs from the other side of the starter switch down to the starter. The starter is self grounding and needs no other wires. (Make this a different color) 3. Ignition circuit: Run a wire from the "common connection" point of the terminal block to one side of the ignition switch (probably marked bat. From the other side of the ignition switch (probably marked ign), run a wire to one side of the ballast resister. From the other side of the ballast resister, run a wire to the coil. (another color) 4. Light circuit: Run a wire from the "common connection point" on the terminal block either side of the light switch. Run another wire from the other side of the light switch to the headlights. Since these are internally grounded, no other wires are needed. (4th color) Now because you have the additional "excitation" circuit back to the alternator, run a wire from the ballast resister side of the ignition switch to either a marker lamp or diode. From the other side of the (markerlamp), run a wire to plug P1. Run a short jumper wire from P2 to the large post on back of the alternator.This is a part of the charging circuit and should be the same color as the charging circuit. Hope this helps..JMHO...Ron
