Order Ford 8N Parts Online
Elenco Conversion (8n vs 600-800 rear end ratio)
8nfever
03-28-2006 15:13:04
I'm installing an elenco conversion on a 1952 8n. I want to validate drive ratio to ensure compatibility between front axle and rear axle. I know I can change sprocket size on the chain that runs the transfer case or play with tire size to resolve issues but I would like to know if the 8n has the same rear ratio as the 600-800 series tractors. If so I should be close if I use the original tires and sprockets.
Thanks,
Steve
8nfever
03-29-2006 09:36:09
 PIX Elenco Conversion (8n vs 600-800 rear end rati in reply to 8nfever, 03-28-2006 15:13:04
third party image
Kelly,
Here are the pictures ..... ..
Steve
Kelly Jewell(KY)
03-29-2006 11:13:05
 Re: PIX Elenco Conversion (8n vs 600-800 rear end in reply to 8nfever, 03-29-2006 09:36:09
Steve, lookin good, looks like it was made for it. You need to call Tony Jacobs, his shop number is 413-267-5087 and cell is 413-668-6950.....Kelly.
FLtom
03-28-2006 19:04:36
 Re: Elenco Conversion (8n vs 600-800 rear end rati in reply to 8nfever, 03-28-2006 15:13:04
A search on this site brought up a response from Tony who listed his email address as:
TJACOBIE5@AOL.COM Give it a shot.
8nfever
03-29-2006 09:59:33
 Re: Elenco Conversion (8n vs 600-800 rear end rati in reply to FLtom, 03-28-2006 19:04:36
Thanks,
Steve
Kelly Jewell (KY)
03-28-2006 16:32:04
Steve, won't you be going so fast in that Florida sand it won't matter. Post some PICS here or on your web site would like to see..... .Kelly Jewell.
8nfever
03-28-2006 17:26:01
 Re: Elenco Conversion (8n vs 600-800 rear end rati in reply to Kelly Jewell (KY), 03-28-2006 16:32:04
Kelly,
I'll get some pictures online tomorrow. I'm looking forward the getting in the sand with it .....
Steve
Jim.UT
03-28-2006 15:27:13
The owners manuals for both 8N and 600/800 say the following:
8N rear axle ratio: 6.66 to 1
600 rear axle ratio: 6.66 to 1
800 rear axle ratio: 7.17 to 1
8nfever
03-28-2006 17:16:33
 Re: Elenco Conversion (8n vs 600-800 rear end rati in reply to Jim.UT, 03-28-2006 15:27:13
Jim,
Thanks for your response. Based on the details you provided there must have been different elenco ratio's unless the tire sizes were different between the 600's and the 800's. I was hoping they were all the same. Thanks again ..... .
Steve
Jim.UT
03-28-2006 17:45:00
 Re: Elenco Conversion (8n vs 600-800 rear end rati in reply to 8nfever, 03-28-2006 17:16:33
I don't know about the details and specs for Elenco parts, but I do know the 600 and 800 rear ends were different. The 800 rear is visibly larger than the 600.
Have you talked to Tony Jacobs? He's the man when it comes to Elenco. He bought out the remains of the company when they went out of business. I have his email somewhere. If you want to contact him, send me an email.
