engine trouble
RandyNark
03-29-2006 18:59:34
Are there short blocks or long blocks available for 8n's or do you have to overhaul yourself.
old
03-29-2006 20:40:27
 Re: engine trouble in reply to RandyNark, 03-29-2006 18:59:34
Heres some number from a val----- bilt catalog. New block with head, not rebuilt but NEW $2630.89. Rebuilt short block $1859.99. Sleeve kit $348.89. So you see lobor is a big cost with an engine rebuild. You can figure even with machine shop work you can build an 8N engine for around $1000 if you do it your self less if its still in good shape other then needing TLC
Bob
03-29-2006 19:04:21
Rebuilts are available for ridiculously $$$$$ more than it will cost you to OH it yourself, if you have a good block to build upon.
TheOldHokie
03-30-2006 05:26:17
 Re: engine trouble in reply to Bob, 03-29-2006 19:04:21
Make sure you're comparing apples to apples. My 9N "rebuild" which I'd roughly equate to old's Valu... link rebuilt long block probably cost about the same. Their description describes the block as "reconditioned". That can cover a lot of ground and a lot of money even at the modest rates my shop charges. In fact given I had to buy a new head and block to replace my cracked ones (determined only after the cleaning and magnafluxing) I probably wound up spending more.
And when you get into newer motors I've given up rebuilding. IMHO a quality "remanufactured" modern long block can't be matched price wise do-it-yourself. The economies of scale make it way cheaper for a mass producer than a one-off job IF you do as complete and thorough a job yourself. Heck the time saved alone is worth a few extra bucks.
YMMV,
TOH
