Paul..... ....yes, it is true, the 3rd-brush 1-terminal 6-volt genny has an OPEN-CIRCUIT volts output in excess of 12-volts (I've read as high as 17-volts) ...but... the minute you LOAD the genny output with a BATTERY, (or ignition coil) it sucks the volts down to about 7 1/2-volts. You do know what open-circuit means don't you? It means NOTHING CONNECTED. nada, zip, understand? Generator polarity depends upon battery polarity and is determined by POLARIZING both the mechanical cutt-outt electro-magnetic core and the genny electro-magnetic FIELD. This is "polarizing" is auto-magicically accomplished by arc-sparking the 2-terminal cutt-outt connections together (tractor OFF). A diode used as a 1-way switch (which is what the cutt-outt is) does NOT need polarizing, it just needs to be correctly wired to begin with. Incorrectly connected, it will drain yer battery and NOT CHARGE yer battery. The cutt-outt relay is NOT voltage sensitive, it is operated by electo-magnetic field strength which is a direct function of current (amps) flow. But it is also electro-magnetic polarity sensitive which is how and why it connects and disconnects the genny from the battery. Howsomevers; 12-volts on yer cutt-outt will burn-out the 6-volts electro-magnetic coil. The OEM 6-volt squarecan ignition coil has a mandatory requirement for the "infamous ballast resistor". To continue to use the OEM 6-volt coil requires BOTH the ballast resistor AND a 12-to-6 volt converting resistor. 8NE-10306 is one of many that is available. FYI...for a while after the early 8N's, Ford offered a 6-volt, 3-wire genny conversion kit. But iff'n you want a roundbarrel 12-volt genny look, look for a Ford Falcon 12-volt genny and matching squarecan voltage regulator. You write..... ."Please don’t write about how I should leave it 6 volts. I’m not trying to start a big debate about 6 volt verses 12 volt so no politics please"..... ...guess what? I don't care, 6 or 12-volts, but you are dangerously ill-informed about electrical circuit theory..... ...respectfully, Dell, a 12-volt advocate for the right reasons and you ain't gott the right reason.
