Order Ford 8N Parts Online
8N engine slows down but doesn't stall
Rudy's 8N
04-03-2006 16:57:01
Just launched my '49 8N after new paint job. Looks pretty. But noticed after engine warmed up and at 1/3 throttle, engine started to lose power for second, then recover. Then lose power again, then back to normal. Never stalled, but sounds like it might. Got even worse when opened up throttle to 1/2. I found that if i choke it during the slow down, it comes back to normal and stays there a while. I'm thinking may be starving for fuel --- just cleaned out all the fuel screens & tank, maybe misadjusted carb? Don't think is governor, but who knows? thanks.
Dell (WA)
04-03-2006 18:02:57
 Re: 8N engine slows down but doesn't stall in reply to Rudy's 8N, 04-03-2006 16:57:01
Rudy..... .could be surge from yer governor. Could be weak sparkies. Could be float level. Could be clogged fuel filters. But most likely is "lean-carb". So simple to check (pullin' choke alittle-bitt is good check). So simple to "fix". ENRICH yer down-pointing mainjet 1/8 turn (atta time) CCW (keep count of yer 1/8's turns)..... ...Dell
Rudy's 8N
04-03-2006 19:16:52
 Re: 8N engine slows down but doesn't stall in reply to Dell (WA), 04-03-2006 18:02:57
Thanks Dell!
