Limiter chains
phil_in_WA
04-04-2006 16:47:48
In reponse to my post 2 days ago there was a discussion of limiter chains. Claim was there were even directions in the box. Now the question pops up, Where do you buy the box?
Also where do the pins to attach the mower to the 3 point come from.
As you can tell I know almost nothing about hooking up things to an 8N so thanks for bearing with me. I would just hate to be missing something and unable to play with the new toy :-)
FLAcharlie
04-04-2006 18:12:33
 Re: Limiter chains in reply to phil_in_WA, 04-04-2006 16:47:48
third party image
Here's the paper that came with the chains I got, which I am very happy with.
FLAcharlie
04-04-2006 18:13:43
 Re: Limiter chains in reply to FLAcharlie, 04-04-2006 18:12:33
third party image
And here is the pic of said chains on my 8N
Paul L - Ohio
04-04-2006 20:32:02
 Re: Limiter chains in reply to FLAcharlie, 04-04-2006 18:13:43
FLAcharlie,
I am curious, what do you have the lower part of you chains hooked too? Are they on the lift ares of on the bolt running through the stabilizer bars?
I was going to build a set myself this weekend and was just curious on how yous worked since mose of the pics I have seen had them bolted to the mover deck. I woould think having a less severe angle on the chains would make them more accurate in keeping level.
Thanks,
Paul
FLAcharlie
04-05-2006 04:33:48
 Re: Limiter chains in reply to Paul L - Ohio, 04-04-2006 20:32:02
yes, same bolt as stabilizer bar, as per drawing in the instructions that came with them. only issue I had was that on one side, having the limiter chain piece in there too left little room for the regular lynch pin, I had to use a large cotter pin, which seems OK. Didn't have the problem on the other side for some reason.
8N'r
04-04-2006 18:03:50
Phil---look to the left of the forum---Tractor Parts---usually the folks that host this site offer most of what you need. If you cant find what you are looking for, email me and I can help you out.----Tim
StahlMaster
04-04-2006 18:02:20
Stabilizer Chains E-Bay Item:9506423723
third party image
Stay Chains E-Bay item:9506423819
third party image
You can get the pins to attach your mower to the 3 point at any tractor supply house. I think they are called "Lincoln Pins" sometimes 10 for a dollar.
