Front mount dist. Problem
old
04-05-2006 14:10:16
Well I finally started to work on the 2N today. I even got it to run for a little bit but the points can't be adjusted as they should be. No mattr what I do I can't get the gap wide enough for them to work right. Is that a point problem or a distutor problem?? I would have pulled the dist from a 9N but it started to rain so I came in the house instead.
don b
04-06-2006 08:49:41
 Re: Front mount dist. Problem in reply to old, 04-05-2006 14:10:16
Sounds like you got bad points, get bluestreak. don b
Ron Tron
04-06-2006 06:52:28
convert to the pertronix module and you'll never need worry again.
JohnMD
04-06-2006 04:35:45
I have had problems with some TISCO points. The set marked Part#ATK6FFR seems to work OK but the set marked Part#APNI2000ABSR has had a problem with wearing down very quickly or not being able to adjust open far enough as you discribed. Check to see which set you have. It may be a function of who makes them. I do not know why there are different numbers. They both look the same to me. Also if the bushing in the distributor is badly worn you will have a problem making the adjustment. Check for shaft wobble.
Bob
04-05-2006 17:23:04
There have been reports of such trouble with "offshore" manufactured points being made a bit wrong, so the gap can't be set correctly.
They must be REALLY off, if you can't get the points set to the (narrow) .015" gap!
Stickler
04-06-2006 04:29:31
 Re: Front mount dist. Problem in reply to Bob, 04-05-2006 17:23:04
I only buy "Blue Streak" brand points..... ...I get them from my local Acklands/Grainger
old
04-05-2006 18:41:39
Yep there very bad. You can open them up enough if and only if you remove the one screw that holds the points down.
Tom N MS
04-05-2006 16:55:28
Sounds like the rubbing block on the points is worn off..
