Pilot..... ..yer low compression (6.0:1) 2N engine was designed for 70 octaine gasoline and cooler Champion H10 sparkies. Hotter sparkies like the H12 would cause pinging and pre-ignition with 70 octaine gasoline when tractor was worked hard, like plowing. Modern no-lead gasoline is 88 octaine gasoline that doesn't ping in low compression engines; and the natural process of combustion leaves behind "carbon" deposits that will foul cool plugs. Increasing the "heat-range" of the sparkie will help to burn-off these deposits and reduce fouling. Champion H12 would be a "hotter" sparkie, H8 would be a COLD sparkie for high-compression racing engines. My latest Champion sparkie information indicates they no-longer make the H12 or H14. They do make a much "hotter" RH18Y. It is a "resistor" plug designed to reduce radio-static interferance. The resistor requires a HOTTER sparkie than yer squarecan ignition coil can sparkle. DO NOT USE RH18Y, understand? Most N-Engines are best sparkled by an exposed tip sparkie like AutoLite AL-437. It is a "hotter" sparkie that burns-off deposits better than the enclosed/shrouded Champion H10 or H12 which tend to foul eazier. And NO, hot spark plugs don't burn exhaust valves..... .....Dell, yer self-appointed sparkie meister
