Asphalt (kinda OT)
Paul L - Ohio
04-06-2006 03:51:14
My property has a couple old asphalt patches that are anywhere from 2' x 4' to 4' x 10' They were old animal pen areas from a prior owner..
I don't have a loader on my tractor, but I do have an old single bottom plow and a sub soiler.
I was thinking that the asphalt is usually just a few inches thick and the I would just need to get it into managble chunks to haul off.
Anyone every tried these for pulling out or tearing up asphalt?
Will the 2n be able to do this?
Thanks,
Paul
Dell (WA)
04-06-2006 09:54:02
 Re: Asphalt (kinda OT) in reply to Paul L - Ohio, 04-06-2006 03:51:14
Paul..... ..use sub-soiler.
Heres the deal, many times low-roll asphalt is used as a livestock pen bottem because it is POROUS and lets fluids (urine) pass thru thus keeping the pen dry. Popular for both pig-pens (thats about yer size quote) and horse stalls..... ..Dell
dozerhand150
04-06-2006 08:47:49
i am a heavy equipment operator in NW Indiana. In my experiences with older farm asphalt slabs the are "usually" just laid on a thin bed of stone if anything at all some times they are just laid in the black dirt that was already there. i agree with souNdguy that i would first dig up a cornerand figure out what you have thickness and such usually not more than a couple of inches of black top. a driveway is usually only 3 inches thick around here if this is the case your single bottom plow will probably be your best bet you can get under the black top and it will flip up and out of the way as it breaks up. good luck.
souNdguy
04-06-2006 05:28:33
I don't think I'd sacrafice a plow to it.. perhaps the sub soiler if it is the solid shank type.. one thing though.
Asphalt is usually laid over a stabilized sub base, and a finish base. finish base could be reclaimed concrete, lime rock, clay, soil cement, or simply.. black-base.. which is just an extra thick lift of asphalt over the sub base. Sub base is usually native soil or soil mixed with any of the above materials I mentioned the finish base could be made of... and then both are compacted in lifts. If these pen sites were made like roadbed.. you could be looking at 1+/- inches of asphalt ( no big deal ).. and then 4-6-8 inches of finish grade.. and 4+ inches of sub grade.. all compacted. if soil cement or reclaimed concrete or limerock was used... It could be setup quite solid... I'd test an edge with a shovel and see what you have. Also not uncommon to pave over a concrete slab! If it is deteriorating, and digs easilly, I'd think the middle buster, or a box blade scarifier might rip it up.. other than that... you may want to use a pick axe. ( I work for a large GC.. roadbuilding is our main business.. )
Soundguy
gahorN
04-06-2006 11:42:13
 Re: Asphalt (kinda OT) in reply to souNdguy, 04-06-2006 05:28:33
Yep. If it's laid over rock/concrete...you could do a back-flip and kill yourself. Get a shovel and find out what's down there fust.
maplehillfrm,pat
04-07-2006 05:48:28
 Re: Asphalt (kinda OT) in reply to gahorN, 04-06-2006 11:42:13
naa he wouldnt flip it completely over with a 3 point hitch implement on it,, he aint pulling anything with a chain or anything,
