Over the years, the aftermarket "12-Volt" coils simply have not had a good history on 12-Volt alternator converted systems. They don't seem to run as cool internally as metal "round-can" coils, and the insulative tar melts, and the coil eventually fails. Perhaps that has now been remedied, and the coil you have is "OK" to run without a resistor, but who knows? I guess, if it were mine, I'd go with the 1/2 Ohm 20 Watt resistor, to be on the safe side. So long as the tractor starts and runs well (has adequate spark) WITH the resistor, I can't see a downside to it. It should provide a margin of safety to the coil, AND the module, because if the coil shorts, it will typically "smoke" the module. I have not yet done one of these Pertronix conversions on a front-mount, although I have used DOZENS of the Pertronix modules on other applications. The Pertronix modules are GOOD, but they have one nasty quirk. If the ignition switch is left on by accident, without the the engine running, the module will keep current flow through the coil 'till the battery goes dead, heating the coil AND the module. Pertronix makes a newer series of modules for common applications, called the "Pertronix II". These are "smarter", and switch off the coil current when engine rotation is not present. It doesn't look like they are offering one for the "N"'s at this time. As you probably know Pertronix also makes a "round-can coil" conversion kit for this application. If I were installing a Pertronix on a front-mount, I would seriously consider that option.
