Well I got the 2N to run BUT part 3
old
04-07-2006 11:19:00
Well I went out and checked compression on all cylinders and I now have around 90 PSI on each of them when the engine is cold. All 4 cylinders now fire, but it still smokes like a frieght train. Guess maybe I should change the oil, since I don't have a clue what weight oil is in there and I also know it has some tranny fluid, PB blaster and maybe even some turpentine in there. Oh well if some one doesn't go for my package deal I'll pull that engine and put it on the 9N that has the sherman and also when I do that I'll change the oil who knows it might slow down the smoke.
Empennage
04-07-2006 16:13:41
 Re: Well I got the 2N to run BUT part 3 in reply to old, 04-07-2006 11:19:00
Old,
Do you have a picture of this 2N?
old
04-07-2006 17:51:07
 Re: Well I got the 2N to run BUT part 3 in reply to Empennage, 04-07-2006 16:13:41
Not at this time I don't. Right now the hood is off and so it the radaitor. I does have factory lights on it but they don't work. Why??
Empennage
04-07-2006 18:08:53
 Re: Well I got the 2N to run BUT part 3 in reply to old, 04-07-2006 17:51:07
I was just curious to see how she looked.
old
04-07-2006 19:14:01
 Re: Well I got the 2N to run BUT part 3 in reply to Empennage, 04-07-2006 18:08:53
Right now it just loks like a bunch of parts. At one time it probably had a loader on it because it has the set up on the crank pulley to run a pump.
