Back on pg 4 or 5 now, a discussion about repairing a crack in the engine side bell housing area. I made the probably incorrect statement that these castings were made of cast steel, not cast iron. Bob correctly called me to task for this, so in an effort to learn more, I Googled up "cast+iron" and "cast+steel" and spent a few hours trying to figure this out. My experiences with these metals are based on what I have successfully welded, repaired, and machined. The ones that were not successful, I called "cast iron" with obvious high amounts of crap formed within the casting. No doubt cheap cast iron made in some offshore place.After studying the matter, I have now learned that there are many different receipes for cast iron. As one site put it, "saying 'cast iron' is like saying 'Sunday Dinner'...there are thousands of receipes that can fit that description. And after viewing other sites, I am pretty sure that state of the art for engine manufacturing includes cast iron and cast aluminum blocks. I do not find any reference to cast steel engine blocks. At a website from the Univ of Washington, I found some description of the chemical analysis of cast iron and cast steel. They are both basically iron and small % of carbon. There are many different formulations that include small % of other metals such as Chromium, Molydebium (sp?), Tungsten, etc that give very different strength and machinability characteristics. Some of the specialty cast iron gives a superior friction wear property. This is probably a desirable property for engine blocks. Some of the additives to the receipe give a different grain structure to the casting. When working with a broken casting, you can see the grain structure in both cast steel and cast iron. Now, in simple terms, what is the difference between cast steel and cast iron? My guess is that cast steel has less than 2% carbon, and cast iron is up in the 3% to 5% carbon content, and this affects the grain structure. (Where is Llamas when we really need him??). Bottom line for all of us....the castings of the engine, transmission, and rear end of the N series tractors are good quality cast that is repairable by welding processes. There are many specialty welding companies and processes that have been developed to accomplish this task. One interesting website I found is www.muggyweld.com, having streaming video of the repair process. Thanks to Bob for challenging my statement, and gently pushing me to learn some more about the metalurgy of our great machines. I hope that some others will add their knowledge to this discussion. Paul in MN
