Oil filter fitting?
poppey
04-11-2006 15:47:30
Anyone know the specs on the brass fitting in the bottom of the oil filter container on 8N side mount dist? Brass, male/female?
Dell (WA)
04-11-2006 16:52:55
 Re: Oil filter fitting? in reply to poppey, 04-11-2006 15:47:30
poppey..... ....according to my N-Ford MPC, both the oilfilter input (from pressure gauge "T" fitting and oilfilter drain (to governor cup) are p/n: 87971-S; 1/8" x 7/16-24 thread connector. Tip: 7/16-24 is called EFT (extra fine thread) 7/16-20 is NFT..... ...Dell
Bob
04-11-2006 15:49:38
My GUESS would be 1/4" inverted flare X 1/8" MPT.
poppey
04-11-2006 16:08:21
 Re: Oil filter fitting? in reply to Bob, 04-11-2006 15:49:38
Is the 1/8 MPT fine thread?
Bob
04-11-2006 18:21:22
 Re: Oil filter fitting? in reply to poppey, 04-11-2006 16:08:21
I thought they were simply 1/4" inverted flare X 1/8" Male Pipe Thread. I will be going back to the shop in a couple of hours, and will "eyeball" one, and post back LATER tonight!
poppey
04-12-2006 17:48:13
 Re: Oil filter fitting? in reply to Bob, 04-11-2006 18:21:22
You were correct. thank you
