Just some info to pass on
old
04-11-2006 16:05:52
Pulled a clutch off a 9N today, it was sticking unless you started the tractor in gear. Well I found that the rivits that hold the disc togeather are loose. Bet thats why it would stick all the time. Hope this can help others
Empennage
04-11-2006 16:24:52
 Re: Just some info to pass on in reply to old, 04-11-2006 16:05:52
old,
Was it an original clutch? Or was it a newer one?
old
04-11-2006 17:05:31
 Re: Just some info to pass on in reply to Empennage, 04-11-2006 16:24:52
Don't know, this old tractor is going to be a parts machine. If has a bad knock in the eninge and I know at least one rod bearing is bad. I'm useing 2 tractors to make one good tractor.
