12V Alternator bracket from YT any pics?
rwacho
04-14-2006 20:12:29
I'm just getting started on the 1950 8N that I used when I was growing up. I'm in the process of changing fluids, converting it to 12V and installing an electronic ignition. I'm at the point where I'm not sure how to utilize the brackets that came for the alternator. They are like the ones listed in the YT tractor store for the side mount distributor style. Anyone have/can get a picture of how the brackets are installed? Thanks to this forum, I've discovered what year my tractor is.
Ron
Hobo,NC
04-15-2006 16:51:04
 Re: 12V Alternator bracket from YT any pics? in reply to rwacho, 04-14-2006 20:12:29
Kin not find the pix rite now. You use the original gen. bracket and bolts and bolt the lower alt bracket to it, Bottom bracket izz E-zee, the longer bracket bolts to the front bolt were the lower alt bracket bolts to the original gen. Bracket and to the water pump tab that sticks out were the original gen adjuster wuz. The short bracket bolts to the top of it and used to adj. The belt. If you kin not git enough adjustment you kin rotate the lower bracket out sum to swing the alt out then retry the top adjuster.
