What size flail mower will my tractor handle?
Rick Hall
04-14-2006 22:33:30
My aunt gave me a 1947 8N. After new paint, hoses, fluids, front wheel bearings and steering linkage overhaul it looks and runs great. Will it pick up and run a Rear 72" fail mower that is 830lbs?
Kevin in OK
04-15-2006 13:17:53
 Re: What size flail mower will my tractor handle? in reply to Rick Hall, 04-14-2006 22:33:30
Ours will run a five foot flail pretty well in just about all but the tallest thickest grass.
Kevin
Dave H (NY)
04-15-2006 05:17:33
Rick, I have a 6 foot Ford 917 flail and it is way more then the 8n can handle in other then ideal conditions. I use the flail mower regularly on an 860 with no trouble. If you are cutting dense or heavy stuff with the 8n use a bush hog, if you are just looking to mow grass look for a finish mower, up to 6 feet should be ok on your n.
Blackhole49
04-15-2006 04:53:03
I used a 72" flail on my first 8n. Cut a 3 acre yard with it for several years(grass). Was much happier with a finish mower (60") once I could afford it. When I changed to a hydrostatic Kubota I never looked back. Still have the N though.
Paul L - Ohio
04-15-2006 04:35:33
Most folks say that the flail mowers require too much horsepower to be effective on our tractors. If you did try it you would probably end up taking partial passes to get the job done.
Most here are using a bush hog style mower (5 feet) or a finish mower (5-6 feet). It depends on what your needs are.
Paul
bcPA
04-15-2006 02:24:24
My 8n runs a 7 ft flail mower in weeds but wants to overheat after a half hour of use.
Dean
04-15-2006 00:46:54
Rick:
It may lift it but it will not have enough power to pull it in anything but very light conditions.
Dean
