Best way to add connectors to coil
Paul Schultz
04-15-2006 16:05:07
I did a 12 volt conversion last year on my 53 Jubilee. It has been great. All winter the tractor fired right up with ease.
When I performed the conversion I switched to the NAPA 12V coil (the one always referred to on this forum...don't have the part # handy). It had 2 posts for the low voltage connections. I rigged up a connection which is holding OK. But, is there a special connector I could get to add to the wiring so I can ensure proper contact. I'm worried things could loosen up some time in the future.
I was considering pulling the coil and soldering short wires with bullet type connectors. I would then have the mating connectors on the wires that attach to these.
Let me know of the 'proper' way to do this (if there is one!)
Paul.
Bob
04-15-2006 19:17:54
 Re: Best way to add connectors to coil in reply to Paul Schultz, 04-15-2006 16:05:07
Are the posts on the coil threaded, or did they sell you a newer-style coil for Ford applications that has posts with a flat top, and no threads?
If that is what you have, you should be able to get a connector like THIS:
Third Party Image
dave guest
04-15-2006 19:07:02
A good solder connection which first is mechanically secure by twisting or winding can't be anything but good, unless it precludes easy parts changing. Rosin core of course not acid.
Jerry/MT
04-15-2006 17:32:16
NAPA has some push on spade connectors for the wire and my NAPA coil came with the spades on the threaded terminals. I just put the female fittings on the wires with crimps and slid the wires on the spade.
Paul Schultz
04-15-2006 19:33:41
 Re: Best way to add connectors to coil in reply to Jerry/MT, 04-15-2006 17:32:16
Mine has the flat topped terminals, no threads. That connector in the pic looks like exactly what I need. Where did you pull that pic from (i.e., where can I get one of these!).
Thanks,
Paul.
Bob
04-15-2006 20:39:49
 Re: Best way to add connectors to coil in reply to Paul Schultz, 04-15-2006 19:33:41
Too bad they didn't sell you the proper coil, with threaded posts, in place of those "Ford has a better idea" terminals!
The one shown is a DORMAN part # 85848. (As you may know DORMAN is a generic parts brand available at lots of auto parts stores.) If you want to order it on the 'net, punch in the part # at RockAuto.com. ($4.13)
Or, scavenge a connector from a 1980's Ford car or pcikup.
