Carb problems
Jake88
04-16-2006 08:09:08
I just put a new carb on my 8n.i set the idle mixture screw & it idles fine. tried to set the power mixture screw,ran it up to max rpms,backed the screw out ,couldnt feel any loss of power.did have a lot of backfiring though.backfired while running the throttle up. and backing it off.adjusted the scew until i got most of the backfiring out ,put it under load & got the same thing,backfiring n no power. went through the whole procedure 4 times ,same results. I have changed the plugs,wires,points& condensor,rotor&cap.is there a chance that the governor is bad n causing my problem. anby help would be appreciated.
RustyAL
04-16-2006 18:25:11
 Re: Carb problems in reply to Jake88, 04-16-2006 08:09:08
Your govenor may be bad but sounds like you got timming/ignition issues. Your new carb should be easy to tune. Just set the idle at 1 1/2 turns out and the other at 2 turns. That will get you in the ball park. Also, it is really easy and cheap to check/replace the balls in the govenor.
old
04-16-2006 08:47:18
I'm with Zane, most new carbs if thats what you have instead of a rebuild carb are junk. What does it do if you choke it?? Does it stop backfireing?? If so you have either a fuel flow problem or a junk/clogged carb. What happens if you remove the main jet and run the tractor?? Ya I know doing that may not be good but it will tell you a story if it runs with the main jet out. If it runs with the main jet out you have a clogged up carb or a poorly made carb.
ZANE
04-16-2006 08:23:35
No not the governor.
Could still have carburetor problem if there is any water or foreign material still getting into the carburetor.
Another thing is you said you have a "new" carburetor. The only new carburetors that I am aware of are reproductions of a look alike. Not a Marvel Schrebler original. The reproductions have a plastic venturi and are made and assembled by people who work for a bowl of rice a day. That too may be part of the trouble with your carburetor.
In my learned opinion you are much better off to fix the original equipment carburetor.
Zane
jake88
04-16-2006 15:59:26
 Re: Carb problems in reply to ZANE, 04-16-2006 08:23:35
Thanks fellas the only reason i bought a new one was becouse the screw holes in thebowl were stripped n somebody drilled the holes trying too tap. couldnt getit too seal. thanks jake
injunrick
04-18-2006 06:08:32
 Re: Carb problems in reply to jake88, 04-16-2006 15:59:26
I fixed a stripped screw/bolt with some JB Weld.still holding!
