Order Ford 8N Parts Online
8N ORC / PTO shaft roll-pin size
Indian Creek Ra
04-17-2006 11:59:25
Greetings!
What size roll pin should I expect to need for a '48 8N to hold the ORC onto the PTO shaft? The one that was in there disintegrated from use/abuse and the ORC fell off..!! The local New Holland dealer dont show it in the parts diagram... I was going to use a hand full of drill bits to try and determine the dia. of the hole in the PTO shaft, but thought I'd try the N-series FOAK first...!!
Thanks!
Indian Creek Ranch
04-20-2006 07:58:51
 Re: 8N ORC / PTO shaft roll-pin size in reply to Indian Creek Ranch, 04-17-2006 11:59:25
Thank you, all, for you're advice...!
Like most of this stuff, once I got in there and did it, it became obvious how it all worked...
Tractor's back up and ready to shred, but it's been raining since about mid-night (Praise God) and so now I'll have to wait till it dries up a bit...
Regards;
Mike S
04-17-2006 13:52:41
I think I just used a 1/4" bolt to drive mine out. But you might be looking at a new ORC. Mine did the same thing and the insides were wrecked so I could not reuse it.
Indian Creek Ranch
04-17-2006 13:58:31
 Re: 8N ORC / PTO shaft roll-pin size in reply to Mike S, 04-17-2006 13:52:41
Thanks! looks ok... but I still have to clean it up to be sure... it wasn't under much load when it came loose, so I'm hopin' it's ok..
Indian Creek Ranch
04-17-2006 12:15:32
Found it..!!
The 5/16x2" roll-pin is a very hard slightly oversized SPRING that you haffta collapse by "friction-fit"..... ....Dell
Thanks, anayway...!!
Kelly Jewell (KY)
04-17-2006 13:06:18
 Re: 8N ORC / PTO shaft roll-pin size in reply to Indian Creek Ranch, 04-17-2006 12:15:32
If breaking this roll pin gets to be a problem, take a look at the PTO shaft between the tractor and equipment. The part that slides in and out is usually not lubed properly causing pulling and pushing on the ORC..... Kelly.
Indian Creek Ranch
04-17-2006 13:19:00
 Re: 8N ORC / PTO shaft roll-pin size in reply to Kelly Jewell (KY), 04-17-2006 13:06:18
Thanks for the advice, Kelly... I'll hose it good with WD40... If the roll-pin didn't outright shatter, how would you get it out? there's so much crud on the ORC I can't tell if the roll-pin hole goes all the way through... I've got it soaking... will take a closer look when I clean it up...
Thanks!
Kelly Jewell (KY)
04-17-2006 13:32:21
 Re: 8N ORC / PTO shaft roll-pin size in reply to Indian Creek Ranch, 04-17-2006 13:19:00
Its a hunt and dig process. I've taken a screwdriver and shop rag and dig away the grease through the outer holes on the ORC. Remove the grease fittings or plugs from both sides and when you find the broken part/parts, drive it out.
