I learned something new today about 12 volt conver
Rick H. Ga
04-17-2006 19:10:51
Hi All,
I learned something today and thought I would share it with those who are interested.
I noticed my Jubilee project tractor had a dead battery, from what I assumed was lack of use. When I jumped it off the alternator was not charging (per amp meter). The battery was so dead when I removed the jumper cables the engine died. The 12 volt 3 wire GM alternator conversion has worked like a charm since I finished the restoration over a year ago.
At this point I assumed the alternator had gone bad so I took it back to the parts store and had them test it. They said it was good. I had the battery tested and it had a dead cell. The parts store prorated the battery warranty and I got another new 12 volt battery for $2.49. I reinstalled the alternator and put the new battery in and cranked it and it started charging like it did initially.
What I learned was that the 12 volt alternator charging circuit will not excite if the battery is sufficiently dead.
It’s nice to learn something new occasionally. I hope this helps someone else.
Best regards to all,
Rick
Bob
04-17-2006 19:44:00
 Question for Rick.... in reply to Rick H. Ga, 04-17-2006 19:10:51
How you have your "excite" wire to the #1 terminal on the alternator set up... "Idiot Light", resistor, diode, or connected to ignition switch "ACC" terminal?
Rick H. Ga.
04-17-2006 19:54:01
 Re: Question for Rick.... in reply to Bob, 04-17-2006 19:44:00
Hi Bob,
I used the GM side marker idiot light bulb for the excite circuit. I don't recall exactly how it is wired but I did a lot of research on this forum and others and got it right. I know it is right because, as I said, it has worked terrific.
HTH. Rick
Bob
04-17-2006 20:02:54
 Re: Question for Rick.... in reply to Rick H. Ga., 04-17-2006 19:54:01
That's interesting! I am trying to figure out what went on there... in most cases, it would have "excited" when you jump-started it, and it would have been trying to push electicity into that bad cell, heating up the battery!
souNdguy
04-18-2006 06:47:29
 Re: Question for Rick.... in reply to Bob, 04-17-2006 20:02:54
Bob.. At fist i was guessing that he just jumpe dthe starter.. but then.. that wouldn't have powered the ignition. So i guess he jumped battery to battery, thus powering the ignition. I too am suprised that the alt did not excite. Perhaps it was at a very low idle.. like 400 rpm and wasn't quite enough rpm for the alt to make enough charge current to power the ignition and charge that dead-cell-load battery. My guess is that if it had been revved to 900 rpm.. it would have stayed running... unless the dead battery was a super duper low value load... which.. if it was.. I'm suprised the jump worked.. etc.
Soundguy
old
04-17-2006 21:22:11
Oh no Bob I can explain one to you for once. LOL. The battery was so far gone that, when jumped it toook most of the Zap-U tron and didn't let the alternator get enough to start working. Sort of like what happens when you have a dead short, you can beef your way acroos a dead short but only for so long before it kills every thing. The bad battery was almost a daed short but the good battery beefed its way past it just long enough to cause thing to work. Ya I know it doesn't fit ohms law of a lot of the others but, since the last I knew we still aren't sure how ZAP-U-TRONS work we just keep guessing
Bob
04-17-2006 21:27:03
 Re: Question for Rick.... in reply to old, 04-17-2006 21:22:11
Well, at least (apparently) he didn't let any smoke out of the system, so it still worked with a new battery!
Jim.UT
04-18-2006 13:17:34
 Re: Question for Rick.... in reply to Bob, 04-17-2006 21:27:03
Yep, you're right....smoke is the most essential part of any electrical system or component. If you let the smoke escape from an electrical component, it will no longer work! ;)
old
04-17-2006 21:40:35
Yep Zap-U-Tron do funny things at times. I've seen thing with them that should work but did. Since science never has figured them out to 100% theres alway those times that sort of kick our buts. I still remeber when I was working an a radio and shorted out a chip and it craked, but it worked good so instead of replaceing it the boos said put the lid on and get it out the door.
Doug Carmean
04-17-2006 19:36:25
 Re: I learned something new today about 12 volt co in reply to Rick H. Ga, 04-17-2006 19:10:51
Yup- Just like the old days when you had to have a little bit of water to prime the backyard pump. Guess you guys are all to young----- -----
ozark mike
04-17-2006 22:49:28
 Re: I learned something new today about 12 volt co in reply to Doug Carmean, 04-17-2006 19:36:25
Doug, i guess i'm old enough remember that...
i grew up in a house that had 6 rooms and a path..and in the winter time when it was 40 below you didn't waste a lot of time at the end of that path either..... mike
