Iff'in you had a choice which would you
old
04-18-2006 13:35:55
Use on the front of a 2N/9N hybred. I have a set of fair 19 tires and rims and also a set of fair 16 tires and rims. Which one would you put on?? Also why?? Thanks
Also this has the sherman over drive tranny, if that makes a differance
Dachshund
04-19-2006 06:08:30
 Re: Iff'in you had a choice which would you in reply to old, 04-18-2006 13:35:55
19's unless you run a loader. Friend of mine has motorcycle tires on his 19's and they dont tear up his grass.
Marty 2N IL
04-19-2006 05:12:44
I was just thinking about this yesterday when I was mowing the yard. My 2N steers alot easier with the 19's than the 8N with 550x16's. I also had my choice when I got the tires and rims. I thought the 16's wouldn't cut up the yard like my 2N did I was right but my arms are sore this morning.
Marty
FarmerDawn
04-19-2006 05:01:46
I don't know the difference in how the two look. (OK, OK, I know I missed the boat on this thread, but at least I'm catching up now. :-) It makes me curious about Arthur's rims. Do you measure straight across the metal, or from outside tire edge to outside tire edge to figure it out?
Dell (WA)
04-19-2006 07:06:26
 Re: Iff'in you had a choice which would you in reply to FarmerDawn, 04-19-2006 05:01:46
Dawn..... ...go look at yer tires, size is molded into the side when mfgr'd. But since Authur came with a FEL, good bet that yer frontires are 6.00-16 for the load carrying capacity. Simple, eh?..... ..Dell
FarmerDawn
04-19-2006 19:25:51
 Re: Iff'in you had a choice which would you in reply to Dell (WA), 04-19-2006 07:06:26
Right on the money! I looked at them today (because of your post) and that's just what they say! :-)
Thanks!
Bruce (VA)
04-18-2006 16:46:31
Personally, I just like the looks of the 19's better. But, from a performance standpoint, it is a lot easier to steer w/ 19's, and plowing w/ them is like having power steering. The only downside I've seen is that they will cut soft/wet ground in a tight turn much quicker than 16's. Of course, if you have a loader, 16's are a must.
Mike S
04-18-2006 15:25:20
If you have no plans to use a loader, the 19s will do just fine.
Tim...Ok
04-18-2006 14:10:44
I would go with the 19's,for some reason you rarely see those around here..I just like the way they look..
Tim
CT8N
04-18-2006 14:04:36
I am running on 16s now, but a previous 8N had 19s and it seemed a lot easier to steer. Could be I am just older too.
Charles
